Defrost not working
Old 12-05-2020, 02:15 PM
Default Defrost not working
What would cause this? Everything else works as it should. Its just it blows out of the panel instead of where it should under the windshield. Started it the other day, it began to defrost the window but just stopped and started coming out the dash instead.
This one is on an 02 NA 3800, not my SS.
Old 12-09-2020, 03:00 PM
Nobody has any idea? Ive tried banging on it, beating on it, yelling at it, insulted its mother. Nothings working...
Old 01-04-2021, 08:25 PM
The selector switch operates via vacuum from the the engine. Open your hood, look to the firewall. There is a thin black vacuum line running along the firewall underneath the wiper cowls. It is routed along the back, travels over the left strut tower(passenger side), then down between the battery and fuse-box. From there it disappears into the wiring harness. Check the entire length of this plastic line for breaks or cracks, it is a good place to start.
Old 01-05-2021, 07:37 AM
Hey thanks man.. I didnt even bother checking for vacuum cause I thought it was on the other side of the firewall. Gonna check that later on. Hopefully it helps. Thats actually what I was wanting to hear, vacuum line...
tloughrin
12-22-2013 08:47 AM
Winston7
01-23-2012 09:12 PM
Emnasty600
07-02-2011 09:38 AM
Sdiver2489
12-08-2010 07:52 PM
J-Bob
04-08-2010 08:46 PM
Quick Reply: Defrost not working
