Defrost not working
What would cause this? Everything else works as it should. Its just it blows out of the panel instead of where it should under the windshield. Started it the other day, it began to defrost the window but just stopped and started coming out the dash instead.
This one is on an 02 NA 3800, not my SS.
The selector switch operates via vacuum from the the engine. Open your hood, look to the firewall. There is a thin black vacuum line running along the firewall underneath the wiper cowls. It is routed along the back, travels over the left strut tower(passenger side), then down between the battery and fuse-box. From there it disappears into the wiring harness. Check the entire length of this plastic line for breaks or cracks, it is a good place to start.
tloughrin
Dec 22, 2013 08:47 AM
Emnasty600
Jul 2, 2011 09:38 AM
