Cranks but no start '02 LS
Old Sep 20, 2015 | 07:16 PM
indybleck's Avatar
I've read problems with the MAP sensor but that should throw a code.
Old Sep 20, 2015 | 09:52 PM
Originally Posted by dchildebrand
Plugs are roughly 5000 miles and are NGK. Air filter is same age. New wires as well.
OK, if the car is not starting at all, that should rule out plug/wires/air filter.
Does it make any sounds like it is going to try and start or is it strictly just cranking the starter and nothing further? And you have confirmed you don't have an active security message on the cluster, correct?
Old Sep 21, 2015 | 11:11 PM
Budsjlm's Avatar
Test the coils I think that's what was killing my icm, the last time it did it one of my coils had a giant cracked in it... botom one is ours (dis)
Old Oct 1, 2015 | 04:28 PM
THAV's Avatar
I am literally experiencing the exact same problem. I started with the fuel pump, which needed to be changed because the sending unit was going bad. Now I'm on to the next diagnosis.
Have you found the solution yet?
Old Oct 12, 2015 | 01:12 PM
dchildebrand's Avatar
It does sound like it wants to start. If the accelerator is pressed down while starting it will "run" for a second, but sounds off. I have since replaced the cam sensor as well and checked the MAF, MAP, changed coils and ICM. I have also disconnected or back probed every sensor that I can think of. I have also pulled every fuse as well. No dice. Any ideas?
Old Oct 12, 2015 | 01:13 PM
Nope. Have you?
Old Nov 12, 2015 | 07:23 AM
Anyone ever had the ECM go out on them? I don't have anything else.
Old Nov 12, 2015 | 05:50 PM
KCFITZ78's Avatar
Start with the basics first.
-Fuel: Check for fuel at fuel rail. I understand you have pressure but you might not have volume.(fuse for fuel pump, fuel pump, fuel filter clogged, fuel pressure regulator bad, leaking fuel at engine)
-Spark: Check for spark using an Inline Ignition Spark Checker (spark plugs gap & condition , wires, coils)
-Air: Check & clean (air filter condition, vacuum line disconnected, throttle body opens and closes)
All the above can be verified / tested / checked, rather than guessing, buying parts and just replacing.
Old Nov 12, 2015 | 07:05 PM
All of the above has been done. Fuses are good. Pump is new and filter is nearly new. I have spark and air filter is nearly new and in good condition. Throttle body is clean and operational.
Old Nov 13, 2015 | 10:56 PM
mehlert52's Avatar
What you describe has all the symptoms of a bad MAF sensor, but if that were the case it should throw a code. Did you try starting it with the MAF sensor unplugged just to be sure?
