6th Gen ('00-'05): Crankcase Breather Tube Melted After Bigger TB
Old Sep 7, 2017 | 06:54 PM
Blactoutmonte's Avatar
Default Crankcase Breather Tube Melted After Bigger TB
Hey I recently installed a bigger throttle body onto my 2004 3400 monte carlo. More specifically the 65mm LX5 throttle body, along with the adapter plate from WOT-Tech's website
The bigger throttle body pushed the crankcase breather tube (not 100% sure thats the name. I think it might also be called a harness??) to rest on something hot (can't remember what its called at the time, maybe the EGR?) and it melted the tube into 2 peices.
I got a replacement from a junkyard but I'm pretty sure the same thing will happen when I put the new one on.
I hear theres a filter you can put on the rear valve cover and a blocker for the throttle body tubing but I've never been able to find it. I tried ordering the filter for the rear valve cover and what I got was enormous haha, it didn't work.
Someone on here has to have ran into the same problem as me trying to put a bigger throttle body on so if someone could give me links to buy the right parts that'd be awesome.
Also, would I need to get my car tuned again for getting rid of this tube.
Thanks
File Type: jpg
File Type: jpg
Old Sep 25, 2017 | 10:47 AM
HKnux5112's Avatar
I'm sure there's specific wrap for hoses to block off a lot of the engine heat so they don't melt.
Old Sep 25, 2017 | 12:15 PM
My guess is that it came in contact with the EGR (probably the tube that goes from the exhaust manifold to the EGR). All my years working on 3100/3400 engines, never saw that.
This tube is related to the PCV (Positive Crankcase Ventilation). There are some debates on whether or not to use the factory set up vs a breather. The breather is the "filter" you are looking for. It would allow the system to vent to atmosphere. I believe most auto parts stores sell them. But, you have a problem. On the 3400, the connection for that is under the coil packs and goes into the valve cover. You would have to run a hose from that connection to a breather. OR another alternative is plug the hole on the back valve cover, and replace your oil cap with a breather.
Personally, I would keep the factory solution and find a way to stop the tube coming in contact with whatever melted it.
