Coolant leaking
Old Sep 7, 2016 | 09:53 PM
ktscull's Avatar
Default Coolant leaking
My 1998 monte carlo 3100 is leaking coolant. Looks like the side of the engine behind the power steering pump. Any suggestions would be appreciated. I've already lightly tightened 6 bolts on the head?
File Type: png
Old Sep 7, 2016 | 10:08 PM
That sounds and looks like a Lower Intake Gasket leak.
To confirm, get a radiator pressure tester, bump up the pressure (I think 12 psi would do it) and see if it has coolant bubbling out where the lower intake and the head meet. If it does, then it is those gaskets (replace sooner than later, eventually coolant gets in the oil).
Old Sep 17, 2016 | 07:55 PM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
ditto on Maniacs advice
Old Sep 18, 2016 | 02:37 AM
Teej's Avatar
what the maniac said but I would add that if you drain the system so there is only air and then paint along the gaskets with dish soap, it will detect even the smallest leak because bubbles will form
