Coolant leaking
Old Aug 21, 2009 | 03:12 PM
Dade Chevy's Avatar
Default Coolant leaking
NEED HELP TRYNA FIGURE OUT WHERE IS THE LEAKING COMING FROM AND WHAT PART NEEDS TO BE REPLACE. SOME PEOPLE ARE SAYIN RADIATOR AND OTHERS SAYING WATER PUMP
CHECK OUT THE VIDEO: http://www.youtube.com/watch?v=xaW__7F8E1s
Old Aug 21, 2009 | 04:38 PM
MonteDriver's Avatar
your video does not help, need location of the leak and you could do some investigating yourself and look under the hood.
Is the leak coming from a hose, the block, or form the interior of the car? is the car overheating?
The video is of low quality and does not show location of the leak nor does it give me a reference of where the camera is looking at.
Old Aug 21, 2009 | 04:45 PM
did you ever figure out what the problem with the passenger side cooling fan was?
Old Aug 21, 2009 | 05:04 PM
MAMONTE's Avatar
What year is it, and what engine? How many miles are on it? Are you sure its not an internal leak?
The 3.1L, 3.4L, and 3.8L V6 engines have a very common problem or either blown head gaskets (seen most on 3.1, and 3.4) or intake gaskets (seen more on 3.8L)...
Old Aug 21, 2009 | 06:20 PM
skylark65's Avatar
wow, that looks bad..... check to make sure you did not blow a coolant hose somewhere ( you will see this if you pop the hood).... other than that i would start with a water pump because they are cheep to buy and easy to replace..... then you wanna look at the radiator.....
Old Aug 21, 2009 | 09:08 PM
Dade Chevy's Avatar
yeah i needed a new radiator assembly fan but as far as the leak the radiator is bad. imma get it replaced tomorrow!! thx for the help guys
rjo98
Oct 31, 2012 08:31 PM
iMSeRiOuS
Nov 19, 2011 07:46 PM
Endo
Jul 6, 2011 01:29 PM
rgant_19
18
Dec 28, 2009 08:49 PM
orthokneepa
Sep 5, 2006 03:49 AM
