Coolant Leak,Maybe More
Old Jul 23, 2012 | 02:10 PM
04chevyboy's Avatar
Default Coolant Leak,Maybe More
Okay so my mom picked up a dark blue 01 monte carlo ss with 33k for 5grand.No rust other than one spot by the sunroof(not sure how haha) underneith is clean,loaded with every option other than high sport,with new cooper tires. has need a few little things like hazard switch an a taillight whichi had layin around but now its sysing low coolant an weve had the elbows replaced an the senser but still has the light on an its smelling like coolant.the car is not cooling down very fast at all,it was going to be pressure tested today.only thing i can think of is the intake manifold has a problem? my buddys regal over headed last spring an he had warped his intake manifold so im thinking it could be the starting of my moms,any help or input is welcome as the mechanic said this is a $700 job an im thinking i might be able to do it myself an save my mother the money
Old Jul 23, 2012 | 02:48 PM
Dubstepticon's Avatar
My car says Low Coolant Level like all the time; previous owner said it was a faulty sensor. It comes and goes, but it was gone for at least a week after I had it topped off at a oil change place. Idk :/
Old Jul 23, 2012 | 02:49 PM
Unplug the sensor, the light will go away.
Ignore the sensor. What is the actual fluid level?
Old Jul 23, 2012 | 03:05 PM
Like chibi said check the actual coolant level first and monitor that. Also how is the temp gauge. does it jump around a lot. If it seems like there is always air in the system and the level is fluctuating you have a problem.
The LIM isn't too hard of job if you want to tackle it. GM makes a tool for removing the pushrods.
Lisle Push Rod Remover 2.8L, 3.1L, 3.4L Gm V6 | Wayfair
Old Jul 28, 2012 | 01:14 AM
04chevyboy's Avatar
below the cool level,shes been running hot
MonteSquarlo
Dec 16, 2012 06:18 PM
2000LS
Jan 28, 2008 08:00 PM
autonoz
Dec 28, 2006 12:27 AM
orthokneepa
Sep 14, 2006 07:59 PM
greg fell
Jul 19, 2006 10:59 PM
