Coolant Issue
Old Jun 9, 2019 | 09:42 PM
FatalcMCSS's Avatar
Default Coolant Issue
I recently replaced the Coolant Level Sensor in my '00 MC, but computer still says "Low Coolant Level" and my coolant reservoir is full of coolant. Idk if my reservoir is bad..any help would be great.
Thanx!
Old Jun 21, 2019 | 11:14 PM
Glen01SS's Avatar
The sensor is in the radiator near the battery, designed to come on when the level in the radiator goes below it. I replaced the original 4 years ago, the replacement has gone bad (message comes on and goes off randomly), coolant level is fine, no leaks. I think my system may need to be flushed and refilled. If your level is low in the radiator when the system is cold, it could be a bad cap if no obvious leaks when hot. A new cap is the easiest quick fix.
Old Jun 22, 2019 | 04:32 PM
FatalcMCSS's Avatar
My radiator cap was replaced some years ago
Old Jun 23, 2019 | 08:00 AM
Is the radiator actually low when your light comes on? Obviously don't open it hot, but it could be that something is wrong and not allowing the reservoir to feed the radiator. If you're positive it's not the cap, then check the radiator passage for the overflow to see if its plugged up, lastly check the hose to the reservoir to make sure it isnt plugged.
There really aren't a whole lot of components that could be bad that would prevent flow between the radiator and tank. But I'd start by verifying it's actually low first to make sure it's not a dud sensor.
Old Jun 24, 2019 | 10:55 AM
If it bothers you, and you manually check your fluids, you can actually just unplug it and the light stays off.
I got tired of replacing those darn things, so I just leave mine unplugged and manually check fluids on a regular basis.
Old Jun 24, 2019 | 07:45 PM
Glen01SS's Avatar
I'll second that - that resolves the light coming on for no reason. And those sensors are expensive for basically glorified idiot lights.
Old Jun 25, 2019 | 01:42 AM
FatalcMCSS's Avatar
Hell, I actually wouldn't mind unplugging it but I just wanna make sure there is nothing actually wrong or gunked up etc..I don't even remember the last time my car had a coolant radiator flush
Old Jun 25, 2019 | 10:12 AM
It's just a sensor that sits at the top of the radiator. They get gunked up like crazy. As long as the car temperature is good, and your fluids are there, I wouldn't worry about it.
Old Jul 2, 2019 | 07:34 AM
RUSHTK's Avatar
Thank you for having an informative thread! Will go unplug mine. Now I just need help with the ABS control module.
Old Jul 3, 2019 | 04:40 PM
FatalcMCSS's Avatar
If your ABS and Trac Off light is on in your dash, you need a new Hub Bearing assembly. On which tire, idk
