Coolant Issue
I recently replaced the Coolant Level Sensor in my '00 MC, but computer still says "Low Coolant Level" and my coolant reservoir is full of coolant. Idk if my reservoir is bad..any help would be great.
Thanx! |
The sensor is in the radiator near the battery, designed to come on when the level in the radiator goes below it. I replaced the original 4 years ago, the replacement has gone bad (message comes on and goes off randomly), coolant level is fine, no leaks. I think my system may need to be flushed and refilled. If your level is low in the radiator when the system is cold, it could be a bad cap if no obvious leaks when hot. A new cap is the easiest quick fix.
Originally Posted by Glen01SS
(Post 718030)
Is the radiator actually low when your light comes on? Obviously don't open it hot, but it could be that something is wrong and not allowing the reservoir to feed the radiator. If you're positive it's not the cap, then check the radiator passage for the overflow to see if its plugged up, lastly check the hose to the reservoir to make sure it isnt plugged.
There really aren't a whole lot of components that could be bad that would prevent flow between the radiator and tank. But I'd start by verifying it's actually low first to make sure it's not a dud sensor. |
If it bothers you, and you manually check your fluids, you can actually just unplug it and the light stays off.
I got tired of replacing those darn things, so I just leave mine unplugged and manually check fluids on a regular basis. |
I'll second that - that resolves the light coming on for no reason. And those sensors are expensive for basically glorified idiot lights.
Hell, I actually wouldn't mind unplugging it but I just wanna make sure there is nothing actually wrong or gunked up etc..I don't even remember the last time my car had a coolant radiator flush
Originally Posted by FatalcMCSS
(Post 718098)
Thank you for having an informative thread! Will go unplug mine. Now I just need help with the ABS control module.
Originally Posted by RUSHTK
(Post 718249)
