coolant elbow?
coolant elbow?
My car is a 2001 monte ss 3.8 n/a
The coolant elbow that goes into the LIM broke while driving(accelerating quickly) and I'm wondering if there is a way to get a new one in there without taking the idler assembly or the LIM off? I feel fortunate that I noticed it immediately and pulled over... the temp gauge got just barely above middle and i knew something was up. I had to call a tow truck for the first time today. But at least it didn't overheat and kill my engine.
Any ideas? Is it possible?
It's a piece of cake. No need to remove the LIM. Usually the piece stuck in the LIM can be spun around with a light touch/tap from a screw driver and then pulled out with some needle nose. 30-60 minute job.
BTW - I just had one push out on me a couple weeks ago (I changed it last spring and this year it decided to cause me grief). I read a LOT of people had issues with the Dorman replacements pushing out. Supposedly Dorman early this year had revised these. I bit the bullet and got "genuine GM". The elbows between GM and Dorman are NOT the same, minor differences.
Yea I figured I would have to take that assembly off xD... I was hoping I could get this done quick tonight since i work weekends :/ Luckily i found a loner car until Monday when i get some time. I'm probably gonna just get the gm elbows just because i should. I got all the old elbow out, luckily it was in just two pieces so that's good. Thanks for the responses everyone I really appreciate it.
btw Jimbo7 I drive 95% city... I average 22 mph.
For the record, the genuine GM elbow will eventually brake (it's plastic in a high heat location with hot fluid passing through, so it's inevitable). All I was getting at, the Dormans I was reading have higher failure rates. The common observation is poor o-rings.
Ok so I put in new gm elbows and I don't have any leaks! But It is running a little warmer than it usually did. Before it would settle around the quarter mark on the gauge (180* tstat) now it acts weird and sits around 2 lines above, halfway between quarter and half on the gauge. It does drop to to quarter mark after a while but it doesn't sit there like it use to.
Anyway I bled the air out of the system and a stream comes out when i open the bleeder... so yea. any ideas besides air in the system? Thats what im thinking (hoping)
