computer location
Old Jun 28, 2015 | 05:05 PM
Storman1's Avatar
Default computer location
could someone please tell me were the ecm pcm is located
Old Jun 28, 2015 | 06:38 PM
ohara's Avatar
It is in the air filter box, under the air filter itself
Old Jun 28, 2015 | 07:59 PM
Storman1's Avatar
Default thanks
Thanks weird is car still runs, use a turn signal and the abs, traction control,brakes all go hay wire
Old Jun 29, 2015 | 01:10 PM
If the ABS light is coming on during this, you should be able to have a scan tool check for codes (need one that can read the ABS computer).
Old Jul 1, 2015 | 04:51 PM
Storman1's Avatar
turned out to be ignition switch. just that
whitedi
Mar 8, 2008 09:47 AM
fastback4
Jan 13, 2007 08:42 PM
fastback4
Jan 12, 2007 02:16 AM
whitedi
Nov 15, 2006 02:08 PM
scortch
Jul 11, 2005 04:10 AM
