Compatible parts car for a 03 Monte Carlo SS
Hello,
I bought my 03 Monte Carlo SS 8 months ago and have so far incountered 90% of the common problems these have haha. I work and fix everything myself and am learning as I go, and this site has helped me quite a bit... Hopefully someone can answer a few questions I have... 1. What cars are compatible to use for parts? (I bought a 02 gram prix 40th anniversary) for mainly the transmission, but I would like to use whatever I can off of it. |
Unfortunately the '03 SS was a one off year for the transmission. Any prior or later year is incompatible. The ID tag is on the back side of the differential and will have a number and 2 large letters. Those letters have to match.
Here's an example: 4T65E ID Tag Info As for the other stuff, assuming the Grand Prix has a 3800 engine, everything should be compatible. Axles and suspension, EVAP system and most electronics should be the same too. |
2 Attachment(s)
Originally Posted by plumbob
(Post 697226)
Specs. would be the same, but internal electronics are different. I learned this from Dave at Triple Edge Performance when I needed to replace the trans. on my "03 SS. Dave is a great resource for information on the 4t65e and is always willing to help.
Thanks for the information, much appreciated.
I have another question that has me stumped.. My heat/AC only works on setting 1 & 5. I bought a new blower motor and heater resistor and it's still the same thing!! I looked at the connections in both ends and everything looks bran-freaking new.... I also checked all the fuses and everything was good... I don't know what the next step would be?? |
I suggest starting a new thread for that problem, but most likely the next likely culprit would be the HVAC control module.
Check out this thread: https://montecarloforum.com/forum/mo...r-relay-56788/ |
Do forget to put those roof rails from the grand prix on your monte if you like that kind of look. It should have them being that it's a 40th anniversary. Or post them for sale someone might pick them up off of you
