5th Gen ('95-'99): cold start up fine, dies after 18 min, no (spark)fire afterwards
Old Jan 15, 2013 | 09:25 PM
klc062452's Avatar
Exclamation cold start up fine, dies after 18 min, no (spark)fire afterwards
97 monte carlo, 3.1, V6
I took my car to a local garage, they kept it for like 2 weeks, gave it back and said all they can come up with is possibly the ECM is going bad.....So here I am trying to fix it myself....
When i start the car, it will run perfectly fine for 17-18 min....(no more) then it just dies, like someone just turned off the key,
It will not restart until the next day....
Once it dies, i am not getting any spark to any of the plugs.... I have replaced the following parts in the process of trying to fix it...
Plugs & Plug Wires
3 New Coil Packs
Ignition Control Module
ECM- Flashed to VIN
Fuel Pump
Fuel Filter
2 relays- labeled - IGN SYS
Still runs for 18 min and dies......?
Any help would be much appreciated....
Kenny
Old Jan 16, 2013 | 08:06 AM
Next time it dies, unplug the MAF and see if it starts up again.
Old Jan 16, 2013 | 09:54 AM
nitehawkjcb's Avatar
Try what Chibi said. If that doesn't work, you may need a cam sensor and/or crank sensor.
Old Jan 19, 2013 | 03:45 AM
Perry Mason's Avatar
Crank sensor for this car isn't too much. Beware, there might be two of them. You want the one that doesn't have wires showing. Installation can be a bitch though. Mechanic recommended.
At the moment, I'm having a similar problem with my 95 3.1. It runs for a while and seems to randomly shut off while sitting idle. Also shuts off if idle and I turn the steering wheel far to the sides. Not sure what that is.
bobmcdonald
Jan 15, 2014 07:54 PM
SgtWyatt
Mar 12, 2012 09:44 AM
jl10899
Dec 24, 2010 09:09 AM
jmaddox
Jun 18, 2009 03:50 PM
Enzo354
Oct 15, 2008 01:09 AM
