Code Reader
Code Reader
Ok might be a dumb question, got a 95 MC z34, my ABS and E-brake lights are on, not 100% sure how to work a code reader or if it will even turn the lights off, was told the sensors "could" be dirty, any help would be appreciated, Thanks
OBD-1.5 on the 95, plus it's expensive to buy a code reader that can read ABS codes. You may have to take it to a dealer or someone with a correct reader to get the code.
Unless you just check each sensor, there are 1 for each wheel.
RickCoMatic
02-26-2008 01:56 PM
RickCoMatic
02-18-2008 03:33 PM
RickCoMatic
02-15-2008 09:38 PM
