cluster rebuilds
Old Oct 27, 2010 | 09:10 PM
dcm0123's Avatar
Default cluster rebuilds
2004 Monte Carlo LS
Fuel gage is not registering right. Fairly sure it is the gauge because it does not return all the way to empty when key is turned off. How accurate it is when the key is turned on depends on how far it returns toward empty. The method GM uses to bottom the gauge each time the key is turned on seams as if they calibrate (re-zero) it each time you turn it on.
Folks on line are rebuilding these for $60 saying they are going to replace all stepper motors. Mine has 4 motors. Does it seam logical it can be done for this price?
Has anyone ever succeeded in repairing their own without replacing the motors? If so, how did you do it?
Thank you
duke0466
Oct 12, 2019 09:13 AM
TETCarlo
Oct 11, 2010 12:25 PM
04MonteLS
Jul 20, 2006 11:05 AM
mikeinparts
Jan 10, 2006 12:20 AM
ralphtrent
Sep 21, 2005 03:00 PM
