cluster mileage question
Old Sep 2, 2010 | 12:33 PM
NYGiantsfan's Avatar
Question cluster mileage question
if i get a cluster from the junkyard will it read the mileage off my car or wat ever is on the cluster from the junk yard thanks
Old Sep 2, 2010 | 12:37 PM
Kozentaru's Avatar
I'm not exactly sure, but I'm leaning towards what the old car had on it. If so, I think you can have it programmed. Maybe someone who actually has tried it could tell us more xD
Old Sep 2, 2010 | 01:33 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
What year is your car? If it has the analog style odometer, it should read the mileage of the "donor" car. If you have the digital style, it should read the same as your car. If you change the PCM along with the digital dash, it should read the same as the donor car. Good luck. I'm sure that there is someone here that knows a lot more than me about the issue, but I'm pretty sure that is how it works.
Old Sep 2, 2010 | 02:23 PM
JaxJim's Avatar
I would think that I'll get the mileage info from your car's computer. That's just my guess, however.
Old Sep 2, 2010 | 02:35 PM
bbengineer's Avatar
If it's an 00-05, the mileage is stored in the cluster so it will read whatever the donor cluster had on it (I offer programming for these clusters to correct the mileage to your car.. check out http://www.bbengineer.com )
If it's an 06+, the mileage is stored in the BCM and a new cluster will display whatever your car actually has on it
BBEngineer
Old Sep 3, 2010 | 03:46 PM
its an 02 with the digital odometer...thanks a lot fellas
rich56
19
Jul 17, 2014 06:07 PM
keatonb
Aug 25, 2011 01:00 PM
jpe
Dec 19, 2010 09:38 PM
TETCarlo
Oct 11, 2010 12:25 PM
aussiek2000
Mar 15, 2010 05:32 PM
