Clicking when breaking below 25mph!!?!?!
Old Jun 5, 2007 | 08:23 PM
sjuts74's Avatar
Default Clicking when breaking below 25mph!!?!?!
When I am breaking anywhere below 25mph to stop, I am heaing a small clicking noise thats happening randomly. Also when the clicking noise happens that lights flicker just a little bit. My breaks seem fine when it comes to breaking, just the noise is concerning me. Thanks for your responses.
Anyone please help!![:@]
Old Jun 5, 2007 | 08:24 PM
sjuts74's Avatar
Default RE: Clicking when breaking below 25mph!!?!?!
It is a 98 Monte Carlo LS if that helps.
Old Jun 6, 2007 | 03:15 AM
Mrrench's Avatar
I would check your drive shafts
Check the boots to see if they are torn. If so you will need to pull the axles and clean the joints and install new grease and boots
Old Jun 6, 2007 | 11:08 AM
wiz kidd's Avatar
it could be something stuck in your pads too...possibly need to change brakes
Old Jun 6, 2007 | 12:11 PM
scc24540's Avatar
mine did that and wierdly enough when i removed the hubcaps and put rims on it it stopped, i dunno why or what it was all i know is that it was annoying, id try to clean off the pads and or replace the slide bolts that the calipers move on, this is most likely the culprit
Old Jun 6, 2007 | 11:32 PM
sjuts74's Avatar
Thanks, I will keep those sugestions in mind when I got get it check out.. I was just worried about my breaks going out or something along those lines....
Old Jun 7, 2007 | 07:44 AM
wiz kidd's Avatar
mine more did a grinding...but it was a little chip stuck in each rear pad ...but thats fixed now
Old Jun 15, 2007 | 07:03 PM
sjuts74's Avatar
Ok, I guess it is my anti lock breaks that are clicking... but they are doing it randomly, yet my ABS light isn't turning on... any suggestions? *and no my ABS light isnt burnt out*
Old Apr 11, 2012 | 09:55 PM
raw wheels's Avatar
My 98 has several clicks under the dash as i am coming a stop i still can't figure it out. Wish i could help you.
Old Apr 12, 2012 | 06:44 AM
BlownUptoHigh's Avatar
Sounds the same as my 99. its the abs that causing the clicking noise. Im going to the dealer in a few weeks do a brake flush and see if they can pulse the abs solenoids with a tech2 scanner while flushing maybe that will stop the noise.
