6th Gen ('00-'05): Check Engine Light (P0102)
I took my monte to get emissions testing today and the car failed due to a check engine light. The code was P0102 and it's saying that the MAF is getting low voltage... I think the cause of this is because of a new sensor plug that I may have wired incorrectly... I unplugged the sensor while the car was running, and it stayed running... Does anyone know if there's some type of wiring diagram that I can look at in order to properly wire this sensor plug? Thanks.
Update
So I double checked all the connections for my new maf plug and everything looked good I also found a wiring diagram online... so I know its wired correctly. HOWEVER, the car still has a check engine light after I cleared it (same code). Does anyone know any possible fixes/things I can check? Thanks.
