Check Engine Light on/OBDII reads coolant thermostat
Old Nov 3, 2015 | 05:03 PM
AlexRose's Avatar
Question Check Engine Light on/OBDII reads coolant thermostat
Check engine light came on, on the freeway, need to replace thermostat. Do I absolutely need to drain my coolant to replace it?
Old Nov 3, 2015 | 05:54 PM
3800? If it's a 3800, you can change it with a little coolant loss. No big deal.
3400, it pretty much dumps a ton of coolant out.
