Check Engine light on....again
Old Jan 1, 2009 | 08:24 PM
02Carlo's Avatar
Default Check Engine light on....again
Okay on November the 9th my Check Engine light came on so I to it to mylocal autozone for the free inspection.The report that it was an emission/leak problem. Keep in mind I know nothing about the guts of my car. I then take it to my local Firestone which my family has been going to for over 15 years.The guy that I talked to told me that it would cost over 1300 dollars to repair.He said my antifreeze and oil were mixing(I believe it was those two) and I needed a new intake manifold and I needed new radiator hoses and some other things.I get the car back and everything is fine.....until yesterday.My check engine light comes on again.I did put gas in it the night before and I wasnt sure if I closed the gas cap tight enough so once I did that I thought I was okay.Its still on now so what could it be?
Thanks for any opinions/thoughts.
Also I forgot to mention that the floor part behind my passenger seat is always wet for some reason and it gives off a somewhat sweet smell.I know that sounds odd but what could it be?
Old Jan 1, 2009 | 10:22 PM
RickCoMatic's Avatar
Default RE: Check Engine light on....again
Go back to AutoZone. Have them READ >> ALL << of the CODES and then ... go inside and have them run you the PRINTOUT ... of what Codes were tripped and the complete CHECKLIST of what to TROUBLESHOOT as the possibility for each of the Codes that are showing. Not just the Code Number and what CAUSED the Code to get tripped. GET the PRINTOUT.
Scan it or type it all in so we can see whats going-on with your car.
We don't know what it could be. We NEED the INFO on the Printout. Then, ... we'll know!
Old Jan 1, 2009 | 11:25 PM
02Carlo's Avatar
This is what I got as a print out when I went the first time to Firestone.I'll print my Autozone report tomorrow:
Description
__________________________________________________ __________________________________________________ ____________
On Board Computer Diagnostics
Symptom:Engash Light On-Went to Autozone Evap System Small Leak/No flow Condition/Gas Cap is on tight/Vacuum Leak at engine/Purge or Vent Solenoid Defective/Light cam on Sunday On-Board Computer Diagnosis
Courtesy Check
Courtesy Check
Lamps,Bulbs,Flashers & Switches
PSS220 Oil Switch W/Light
Remove & Replace Oil Pressure Sender or Switch
Cooling System Flush with 50/50 Pre-Mix Antifreeze
TLF108p Coolant Flush W/Sealer and Conditioner
Coolant Flush Labor
50/50 Peak Global Antifreeze
Lubrication Services
7030813 Gas Cap
Gaskets Engine
19169127 Intake Manifold Set
Remove and Replace Intake Manifold Gasket, Lower
70 Intake Manifold Labor
5W30 Standard Oil Change-Up to 5 Quarts
TF47 Oil Filter
5W30 GT-Synthetic Blend Oil
Oil Change Labor
Hoses
Upper Radiator Hose
Lower Radiator Hose
Remove & Replace Radiator Hose,Both
Heating//Cooling System Service
Radiator Cap
Old Jan 2, 2009 | 01:22 AM
Actually, if you have an 'O2 Monte ... you might qualify for the DexCool Settlement. Call Chevrolet Customer Service and tell them your Intake Manifold went and the DexCool caused it.
Old Jan 2, 2009 | 01:57 AM
02Carlo's Avatar
ORIGINAL: RickCoMatic
Please note the following important dates: Date Case-Related Event October 27, 2008
[Expired] Claim Statement Deadline August 13, 2008
[Expired] Request for Exclusion Deadline August 13, 2008
[Expired] Objection Filing Deadline August 29, 2008
at 11:00 a.m.
Fairness Hearing
NOTE: The hearing resumed on October 23, 2008, and the settlement was approved.
I think I missed my chance
Old Jan 2, 2009 | 09:39 AM
whoamioitsme's Avatar
even if it is that you left the gas cap loose witch is a commen cause the light will stay on for some time till it clears
Old Jan 2, 2009 | 07:38 PM
kweef's Avatar
get the code print out and tell us waht it says
Old Jan 6, 2009 | 03:04 AM
5207234w's Avatar
well the wetness and sweet smell is a cracked heater core which resides behind the glovebox. samething happened to my 94 grandprix easy fix if you have some know how.
Old Jan 7, 2009 | 12:15 AM
02Carlo's Avatar
Thanks for that info.I dont smell anything now and my floors arent wet anymore. I took my car to Autozone and it was my EGR Valve.It needed to be cleaned.The guy said it may not fix my problem which gave me a bit of an uneasy feeling.My family has been going to this place for over 20 years though so I trust em not to do any harm to my Carlo.
hotrodharley
Nov 15, 2013 11:37 AM
fwoggybaby
Apr 7, 2012 09:42 AM
WannaMCSS
Dec 14, 2011 09:27 AM
Franks 03SS
Aug 27, 2011 02:53 AM
FourX11gd
Sep 25, 2005 02:08 AM
