CEL P0420
Old Mar 18, 2008 | 04:38 PM
CHOWEE21's Avatar
Default CEL P0420
Could someone tell or show me where the sensors are?
And my car has been running hot, could this be part of it?
I have 2 P0420 codes when i checked it.
Pics or any help will be greatful
Old Mar 18, 2008 | 05:38 PM
rysZ34's Avatar
Default RE: CEL P0420
This trouble code is a couple of things:
An O2 sensor (either one in front of or the one behind the catalytic converter) isn't working properly
Bad coolant temp sensor
Damaged/Bad/Leaking exhaust manifold, catalytic converter, muffler(s)
Some suggested steps for troubleshooting a P0420 code include:
[ul][*]Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.[*]Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady).[*]Inspect the downstream heated oxygen sensor (HO2), replace if necessary[*]Replace the catalytic converter [/ul]
If it is heating up, you could have a plugged catalytic converter, but my bet would be a bad coolant temp sensor. That would be the cheapest way to go. (I believe) Good Luck!
Old Mar 18, 2008 | 06:39 PM
RocknSS04's Avatar
I throw an occational p0420 code. I have a 3" downpipe and Magnaflow high flow cat. ZZPerformance also found a #4 cylinder misfire.
My guess is that you have lots of miles on the car. The code says catalytic convertor inneficiency. Bad cat's don't usually throw a code, but will affect performance SERIOUSLY! Shifting, also. It's not the temp sensor. ?????? Maybe a tune up is in store. I replace the coil for the #4 cylinder, and ordered the other 2 (FACTORY COILS ONLY!) Wires are next, if this doesn't help. I DO know my milage is now better.
Old Mar 18, 2008 | 08:08 PM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
P0420 code is the catalityc converter. What year is it? If it's an '01-'02, check this post https://montecarloforum.com/m_12459/tm.htm
That was the problem with mine.
01whitess
Jul 1, 2013 01:34 AM
NovaSS369
Nov 14, 2011 02:16 PM
Pjw350
Mar 24, 2010 09:00 AM
labnjab
Oct 12, 2009 07:51 AM
brian99_03
Jan 25, 2009 04:27 PM
