Car Wont Start and Key will not come out
Old Aug 11, 2013 | 08:43 AM
Jimmy Criswell's Avatar
Default Car Wont Start and Key will not come out
Hello everyone. I just got my 355 CI completely installed yesterday. I have totally taken the computer out and it was running prior to me pulling my 305. Last night, I got the last little bit of everything installed except for something kind of important. Can someone please guide me to the area to look at? My car will shift but I cannot put the key in the lock position to pull the key out. Also, the car is totally dead. When I turn the key to start it...nothing. I know it has to be wiring. I have 2 good grounds going to the motor so I am not sure what it could be at this point, but time to start troubleshooting. I cannot wait to get this car fired up and driving
Old Aug 11, 2013 | 08:52 AM
Hi Jimmy,
Could be a bad ignition lock or lock cylinder (?) Is it the factory original lock ? > Could just be wore out ?
Check back to see what our expert MCF tech's post when they see your thread problem...> Good Luck
Oh, what year is your Monte ? * We hope you posts/share some pictures!!!!
Old Aug 11, 2013 | 08:56 AM
Replace ignition switch on 1986 monte carlo v8 with tiite - Fixya
www.fixya.com/.../t12388321-replace_ignition_switch_1986_monte_car...
^ Click above link
Apr 12, 2012 - replace ignition switch on 1986 monte carlo v8 with tiite sterr - Cars ... 2002 monte carlo. won't start when I turn the key until about three trys. no ...
How to replace a key ignition switch on a 1988 Monte carlo - YouTube
► 8:10► 8:10
Dec 13, 2012 - Uploaded by ThaStunnaMane
replacing the key switch for a 1988 monte carlo, its the same for any GM ... Key Won't come Out - GM.flvby ...
Old Aug 11, 2013 | 09:13 AM
03SSLE's Avatar
Since you can't get the key out and the engine won't turn over I'd double check the shifter linkage. If the transmission isn't completely in park the key won't come out. If the linkage is not properly adjusted the neutral safety switch won't be in alignment and you will have an 'open' in the starter circuit.
Old Aug 11, 2013 | 09:16 AM
Thanks `Seattle Mike for sharing your auto wisdom 4-Sure...
I never even thought of that > Good Advice Thanks for all your help to our MCF Member's
Old Aug 11, 2013 | 01:06 PM
Default Thanks
I was kind of wondering that since we replaced the detent cable yesterday. It is definitely possible we got something out of place since everything was working before we took it out. I have a 1985 Monte SS.
Old Aug 11, 2013 | 01:07 PM
I have an edelbrock 1406 and bought the edelbrock hook up kit designed for the intake, but I am not positive we have the detent set up 100 percent correctly either. All slack is out of the line though.
Old Aug 11, 2013 | 01:08 PM
If I were to adjust the switch on the shifter side, how would I go about doing that?
schoentges16
Feb 27, 2021 06:43 AM
BrandonStebing
Jul 25, 2014 11:03 AM
Knightwolf702
May 14, 2014 07:13 PM
orthokneepa
Jan 6, 2012 08:56 PM
95silverbullet
Feb 28, 2010 10:46 PM
