6th Gen ('00-'05): Car not turning over-blown fuel pump fuse
Old Aug 15, 2015 | 10:27 PM
305chevydriver's Avatar
Default Car not turning over-blown fuel pump fuse
Good night fellow MCF members I need some help....
Last week I was driving my beloved MC on the expressway when it completed shut off. I was able to swerve to the shoulder of the expressway where I later got it towed home. I searched around and through out my car. Found my fuel pump fuse was blown...purchased a pack of new one ( 15a) put it in ...car crunk right up.....bout 10 min later it died....radio works ..lights and everything else works ..the car just shut off. ( Thank God I have more than 1 vehicle). Today I dropped the tank and found the pump and wiring are in good standings so no problems there. I drove the car around the block then down the street then back down another street. it cut off ...I put another fuse in it but this time nothing. it tried to turn over but nothing.....can SOMEBODY ANYBODY WHOEVER help me out.....
Old Aug 15, 2015 | 11:16 PM
KCFITZ78's Avatar
Do you have a check engine light? If so what code(s) were thrown?
Check for loose ground at pump or could be a bad fuel pump relay/solenoid.
I would bet bad fuel pump relay/solenoid. Relay was probably failing and that is what blew the fuse.
Old Aug 16, 2015 | 12:43 AM
Could be you have a wire grounding out. Here is what I read on another site.
Chevrolet Monte Carlo: 1995 z34 fuel pump fuse
Why would a 97 Dodge Neon keep blowing the fuel pump fuse
Old Aug 17, 2015 | 10:47 PM
nitehawkjcb's Avatar
Agreed on checking your grounds and relay.
Old Aug 22, 2015 | 05:29 PM
KCFITZ78's Avatar
Have you solved your problem?
Old Aug 28, 2015 | 09:19 PM
car still sitting in the garage covered up...still haven't figured out my blown fuel pump fuse...took it to the dealership...they told me they couldn't do a diagnostic test on it because its not stock....( puzzled face)
Old Aug 29, 2015 | 12:58 AM
KCFITZ78's Avatar
What about your car is the dealership referring to as not stock?
Old Aug 29, 2015 | 03:24 PM
they said because my car has hid lighting, custom stereo, intake , etc ....smh I don't understand what that has to do with anything.
Old Aug 30, 2015 | 03:58 PM
Habbibie's Avatar
So as of this moment is the relay good? Did you check the ground? How about running a higher amperage fuse? I kept blowing a fuse for my Aux power so I took the 15A fuse & replaced it with a 25A, it's been over two years since I did that and it has yet to blow that fuse.
Old Sep 4, 2015 | 09:36 PM
still haven't figured this out. I have replaced the fuel filter...the fuel pump..and the fuel pump fuse is still blowing. I have checked all the wiring from the front to the back. I have even pulled out the fuse box and checked all the wiring in there as well. This is getting annoying...
305chevydriver
Aug 16, 2015 06:58 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
midnightsun
Mar 8, 2012 03:46 PM
Mike Monte
Jun 26, 2011 10:27 AM
JoeAsheville
Feb 16, 2009 01:05 PM
