CAN YOU MIX COOLANTS? 02 monte LS
Old Mar 24, 2007 | 11:02 PM
turner_dtp's Avatar
Default CAN YOU MIX COOLANTS? 02 monte LS
I was going to fill my resevoir tank but i remembered i had put green instead of orange. can you mix the orange in with the green color of coolant? i think i read somwhere that you couldnt. im not sure if to mix or not. any help would be appreciated.
Old Mar 25, 2007 | 12:56 AM
Mrrench's Avatar
Default RE: CAN YOU MIX COOLANTS? 02 monte LS
If you are using the non extra life coolant
do not mix with the nex coolant. There is no reason to mix the old with the new
Old Mar 25, 2007 | 12:42 PM
wiz kidd's Avatar
DO NOT MIX COOLANT!
not even the stuff that says its universal....ITS JUNK! your coolant system will go all jelly like.. if its red in there which it should be...stick to red...if its green stay with greeen..
there is a way to put green in these cars and thats to have your entire system flushed and cleaned and then you can put green in instead of red..
Old Mar 26, 2007 | 03:26 AM
2000LS's Avatar
...had me thinking, greens cheaper and doesnt turn into mud... anyone seen any ill effects of running green where the dex cool is called for?
Old Mar 26, 2007 | 10:19 AM
wiz kidd's Avatar
only if the system is completely flushed can you run green...and it wont hurt anything...but the system has to be 100% completely empty of red coolant
Old Mar 26, 2007 | 03:18 PM
GrandPaDave's Avatar
ORIGINAL: wiz kidd
Corrent, and once you go to green, DO NOT go back to DexCool.
tps221
Mar 22, 2013 06:07 PM
Sep 23, 2012 01:33 PM
Jparks
Dec 23, 2010 11:34 PM
my00monte
Dec 14, 2010 04:30 PM
irulesoha
Sep 28, 2010 08:08 PM
