Can you change door chime on 06 MC?
Old 09-03-2009, 08:30 PM
Skimmet's Avatar
Question Can you change door chime on 06 MC?
I think the door chime on my '06 MC is too loud and annoying. Does anyone have any advice or experience in finding a replacement?
Skimmet - Ohio
Old 09-03-2009, 11:03 PM
Taz is offline
That's a good question. I'm kinda curious myself if anyone has done it.
If it's like the 6th gen (2000-2005) Monte's, the sound is programmed into the car and comes through the car's sound system.
Being programmed into the car's computer, it would probably take someone with programming skills. But I'd be interested to know, if someone did it, how they did it also.
Old 09-04-2009, 05:49 AM
Skimmet - Ohio
First, Welcome to our Monte Carlo Family...Tell us about your Monte ?
model/color/pic's : ) ?
.. I think it's a module that can be removed Hopefully one of our Expert Tech's will know if it can be replaced with a softer sounding chime.
I believe you can remove your module, but there would be no sound.
Check back on your thread question to see `if any member responds.
Until then, maybe earplugs (j/k)
Old 09-04-2009, 07:41 AM
Enzo354's Avatar
STILL SLOW
I used to have no driver side speaker when I bought the car, i thought i just didnt have a chime. Then I put in a new speaker and there it was. So annoying.
Old 09-04-2009, 07:57 AM
Below are some links on the subject
door chime module - Chevy Truck Forum - GMTruckClub.com
does anyone here know where the door chime module is located in my 04 Tahoe? .... Impala / Impala SS, Malibu / Malibu SS / Malibu Maxx, Monte Carlo, Volt ...
www.gmtruckclub.com/forum/showthread.php?p=168879 - Cached - Similar
[PDF] FACTORY STEREO REPLACEMENT INTERFACE WITH CHIME (CLASS II DATA SYSTEM)
File Format: PDF/Adobe Acrobat - View as HTML
Monte Carlo. 2003-06. Silverado Pickup. 1500/3500 .... will be re-produced by the speaker built inside the GM09SR located in the dash behind your stereo. ... Add on Chime Module for use with DCGMOS210B, DCGMOS2B11B. AXIPGMCL2: ...
www.scosche.com/ecom/download/GM09SR_SinglePgs.pdf - Similar
ClubGP Store: PAC OS-2 OnStar Interface
We also have the PAC CM1 chime module for use with the OS-2 or OS-2Bose® interfaces only. ... 2000-2004 Chevrolet- Monte Carlo 2004 Chevrolet - Silverado, Venture ... Please select your shipping location in order to proceed to the item ...
www.clubgpstore.com/itemview.asp?itemid=113 - Cached - Similar
Old 09-04-2009, 08:24 AM
What do you do that the chime interferes?
To me, having the chime is a great security feature. It always tells me if I forget something.
Old 09-06-2009, 11:25 AM
It would be nice if you could change the chime to, "Shut the dam door, shut the dam door." Id try to program that if possible.
Old 09-06-2009, 11:37 AM
LOL `Rob,
That's funny 4- Sure. I can think of a few more words to
progam in, but since this is a family forum, I can't
Thanks 4 the funnies : )
"Put on your Freak'in Seatbelt"
"No free ride, you R buy'in the gas"
"No Farting in my Monte"
"SHut `UP `Space"
ok..let me `out
lol
Old 09-06-2009, 02:23 PM
Taz is offline
The chime actually has saved me many times when I left the headlights on.
Mine should say, "turn off your dam lights dumb-***!"
Old 09-06-2009, 06:32 PM
RocknSS04's Avatar
If you go to an aftermarket radio, you will need to install a speaker under the dash for the chimes. Then they will work different, and sound different.
As for changing out the chime itself, no. It's part of the stereo deck.
Quick Reply: Can you change door chime on 06 MC?
