Can anyone point me in the direction of what the name is for this here?
Old Feb 24, 2022 | 06:26 PM
Justchambers88's Avatar
Default Can anyone point me in the direction of what the name is for this here?
Sits in front of the carb with two thin lines running to it
Old Feb 24, 2022 | 07:24 PM
Jeffs02rwdSS's Avatar
With the pictures it's hard to tell what switch it's for. But it's referred to a ported vacuum switch. More information such as year, engine, what the vacuum lines are going to would help get a better answer. Sometimes found on the thermostat housing other times in the intake manifold.
Old Feb 24, 2022 | 07:50 PM
Thank You! It's on an 1983 v8 CL,It looks like it's on the manifold, Thanks again!
Old Feb 25, 2022 | 09:09 AM
zucchi's Avatar
Old Feb 25, 2022 | 11:39 AM
Originally Posted by zucchi
It's some sort of vacuum ported temperature switch that's installed into your thermostat housing/water outlet. Your service manual will have much more info about that. If you don't have a service manual, get one.
CD (https://www.amazon.com/1982-CHEVROLE...%2C123&sr=1-10)
Hard copy (https://www.amazon.com/MUST-OWNERS-M...s%2C123&sr=1-5)
By the way, what's up with the bare wires on the other sensor next to it and the (WTF??) solder job on the idle stop solenoid body?
Thanks! Yea just about all the wiring has to be redone on this thing
Barovelli
Dec 17, 2021 04:30 AM
SolowSS
Oct 20, 2018 02:54 PM
Red Nightmare
Oct 8, 2013 11:56 AM
MnteCrloSS47
May 26, 2012 09:19 PM
osantisbon
Jun 14, 2010 03:48 PM
