a/c wont shut off
Old May 30, 2018 | 11:55 AM
bossman48's Avatar
Angry a/c wont shut off
i have a 2003 monte carlo ss. the problem im having is the a/c wont shut off.
as soon as you turn the fan on. the a/c kicks in.
the switch assmbly is all knew.
any thoughts on what the problem could be?
all fuses an relays are good. new battery terminals.
im at a loss as to what to do
Old May 30, 2018 | 01:09 PM
Is it the A/C turning on, or the compressor turning on?
Are you using a setting with defrost? Does the compressor shut off when you switch it to only lower vent settings?
Old May 30, 2018 | 08:22 PM
bossman48's Avatar
the compressor stays on no matter what you switch it to..
