A/C Knocking
Old May 25, 2012 | 09:47 AM
myronprescott's Avatar
Default A/C Knocking
Whenever my a/c is on & then I turn it off i hear this knocking sound coming from the passenger side, has anyone else experienced this & know what to do.
Old Jun 20, 2012 | 03:59 PM
john213la's Avatar
yeah bro i get the same thing.... have you had it fixed yet?????
Old Jun 20, 2012 | 04:28 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
https://montecarloforum.com/forum/in...-around-36838/
^^^Click on that link. I posted a YouTube video of how to fix. Good luck!
Old Jun 20, 2012 | 04:43 PM
john213la's Avatar
found how to fix the problem...
06+ Impala AC tick fix vid.wmv - YouTube
Old Jun 22, 2012 | 07:10 PM
rainygirl's Avatar
Thumbs down so i got the knock...
This is something I can take on as a novice? or do I bite the bullet and take her in?
Old Jun 22, 2012 | 07:36 PM
03SSLE's Avatar
Welcome to the forum. It's difficult to say whether or not you can take this on or not because we don't know your mechanical aptitude or experience. Have a look at the how-to video in post #3 to determine if it's something you'd be confident in doing.
Old Jun 22, 2012 | 07:56 PM
rainygirl's Avatar
Thanx... watched the video, looks like a lot of busted knuckles and broken nails. Going to attempt this next week if it saves me a couple hundred in labor I haven't lost anything....
Old Jun 23, 2012 | 06:35 AM
03SSLE's Avatar
That's the spirit...I like your determination. Busted knuckles heal and nails grow back so what the heck, may as well give it a go. Not only will you save some $$$ but you'll also have the satisfaction of knowing you took on the challenge and conquered it. Let us know how it comes out.
Old Jun 24, 2012 | 05:18 PM
rainygirl's Avatar
Default another question
When the knocking first started the a/c worked fine, if you experienced the knocking you know it generally occurs when the a/c settings are adjusted or changed.... Now the a/c is still blowing but its coming out as hot as the devils ****, I know the freon is good, compressor is a-ok. Did anyone else have the hot air problem that was resolved with replacing the actuator? or am I looking at a whole new issue?
Old Jun 25, 2012 | 07:30 AM
03SSLE's Avatar
If the A/C was working fine prior to the repair I'd double check my work making sure the actuator mode\temp valves and air inlet are installed correctly.
