Break light switch
Old Jan 19, 2011 | 07:41 PM
Crazy4408pac's Avatar
Default Break light switch
On a 98, where is the break light switch? In back of the break pedal?
Thanks
Old Jan 19, 2011 | 08:23 PM
Enzo354's Avatar
STILL SLOW
Whats the issue, we might be able to help you more?
Old Jan 20, 2011 | 08:06 AM
I'm having intermitent no brake lights. For instance, last night, I checked them and I had break lights. Then I checked running, turn signal and hazard. I checked the fuses and the bulbs. Everything, ok. I tried the brake lights again and only had the window light. But, as my wife pulled out to go to work, she had them. She still had them this morning, when she got home.
Driving me nuts. So, I think maybe the switch. It's 9 degrees and snowing,should be fun laying on my back, to check it. LOL! Is it located behind the pedal?
Thanks
Old Jan 20, 2011 | 06:10 PM
Enzo354's Avatar
STILL SLOW
You check the wiring going to the brake light itself? What year do you have?
Old Jan 20, 2011 | 06:21 PM
you have a bad multifunction/turn signal switch..... check out the thread below!
weird tail light problem
Old Jan 24, 2011 | 12:17 PM
Ok, I'm ready to buy a turn signal switch. Any ideas/suggestions, as to a part number and where to buy? I checked rockauto and am confused as to which switch to get. I have tilt wheel and cruise but no radio control. They have 7 differant switches to choose from. 98 Monte LS
Thanks
Old Jan 24, 2011 | 06:50 PM
Plus, some have one pigtail others two. See below.
File Type: jpg
File Type: jpg
Old Jan 24, 2011 | 07:28 PM
looks like some have cruise control and radio controls in the switch? not sure where you're at but do you have an Advance Auto near you? hope this helps????
http://shop.advanceautoparts.com/web...+signal+switch
BrandonStebing
Nov 15, 2013 09:20 PM
hotrodharley
Nov 15, 2013 11:37 AM
Snobird
May 6, 2013 05:31 PM
Harlan2012
Feb 6, 2013 01:39 PM
gothkid
May 4, 2009 09:54 AM
