Brake performance rotor
Old Mar 3, 2016 | 12:39 PM
99-03SS-07SS's Avatar
Default Brake performance rotor
2 years ago, from the recommendation thru this group, I bought Brake Performance rotors for my car along with Hawks pads.
My hawks was almost out of padding (or whatever it's called), I replaced it with the ones that Brakeperformance.com send a along with the rotors.
About 2 weeks after replace, car is making awful vibration, like rumbling. As if it's hitting the crosslines.
I called brakeperformance.com and they said it's rust and they said nothing they can do. Geez. $150 and 185 something each rotors (front and rear) that last thru ONE pad? I was expecting rotors to last thru 3 pads or so.
I asked them what is solution to it. She said nothing but we can order new ones for you. I asked her if I can turning (did I have word right?) She said it's up to garages to decide if they can or not.
I asked her what caused it. She didn't give me straight reason. It could be... that... blah
I told her it was fine until I PUT YOUR PADS on and then it screwed up... she said it happens..
Anyone of u had experience this?
Turning? Yes or no?
How can I post my pic in here?
Old Mar 3, 2016 | 01:33 PM
Hi `Member, (no name in your profile).
I don't know what group you spoke with over 2 years ago, but we have over 26 thousand member's that could of told you. Most of our member's are just self taught and there are few dealer mechanic's that are not here often.( They deal with car prob's all day & most don't want to after work)..We have many knowledgeable member's that help others...
They learned by trial or error, or took time to research & study.
It's pays to really do you homework before you buy Plus, know the backgrounds of the person you get advice from...
Here's a few links for you to check >Good Luck<
Lesson 10: The Brake System - Crawfords Auto Repair
crawfordsautoservice.com › Car Care Tips
This is one of twelve free lessons on auto maintenance and repair. ... Disc brakes have a rotor (disc) for each wheel and brake pads are the friction material.
Everything You Need to Know About Brakes | Completely ...
www.firestonecompleteautocare.com › Completely Firestone › Brakes
Get to know your car's brakes. Find out how your brake pads, calipers, rotors, and other parts work to make your car stop when you need it to.
Old Mar 3, 2016 | 01:35 PM
Old Mar 3, 2016 | 10:50 PM
Here's the pic of rotors..
Drill the plugged holes out?
File Type: jpeg
