brake lights out
Old Aug 25, 2013 | 03:06 PM
montacarlo98's Avatar
Default brake lights out
my brake lights are out the two at the bottom and my turn signals light are out but my hazard lights still work can someone tell me what the problem is please
Old Aug 25, 2013 | 03:19 PM
Ive never had a problem with mine....
Im guessing you have checked all the fuses? In the dash as well as under the hood? Are all the bulbs good? Does your 3rd brakelight still working?
Heres a guess:
maybe its the Multi function Module? Its in the steering column....
Have any idea what may have caused them to go out in the first place?
Hope this helps!
maybe someone else will chime in with some other ideas/advise!
Thanks for Joining the MCF!
Were always happy to help other Monte Carlo Owners.
Old Aug 25, 2013 | 03:56 PM
yes i check all the fuses and the one in the middle still works the bulbs are new and the brake switch
Old Aug 25, 2013 | 04:00 PM
My wifes 99 blazer did the same thing....
It was the Multifunction Module. (Its in the steering column)
We also tried replaceing the brake light switch...(No help)
Til we found out it was the Multifunction Module...
Old Aug 26, 2013 | 09:55 AM
skylark65's Avatar
i would second it being the multifunction switch in the steering column, mine was bad when i got my '97 monte and it causes those exact symptoms. good news is the part is under $100, bad news is it is kinda involved to replace ( need to remove the airbag, pull the steering wheel and more in the steering column to get to it). so unless you're a skilled mechanic i would reccomend having a shop do the work.
THAV
Sep 3, 2014 07:50 PM
hotrodharley
Oct 11, 2013 07:13 AM
billyjblunt79
May 3, 2013 12:59 PM
Zackb911
Dec 22, 2006 07:22 PM
