brake lights not working.....
Old Jun 25, 2012 | 07:01 PM
jworm98's Avatar
yes sir, i have tried to wiggle the lever, and the lights do not com on at all, thats y i was trying to clarify. evrything on the lever works i.e. wipers, turnsignals, etc. im stumped on where i go from here. im pretty confident its either the TSS or the multifunction lever but cant identify which one it is. any ideas????? thanks again I will try fuse #30 and #5 when i go home for lunch. and the TSS is the round switch under the steering wheel not the multifunction lever? the terminology is confusing me sorry, but thanks again.
Old Jun 25, 2012 | 10:07 PM
jworm98's Avatar
ok, i checked fuses #30, #5, and #23. All were good. blinkers work fine. turn signals work, brakes lights do not do anything when i hold them down and jiggle the multifunction lever. im goin to take a stab at it and try and change the TSS (round shaped switch under steering wheel), i will see if theres anything obviously wrong (broken wire, melted wires, loose contacts,etc). anybody have any other ideas before i dig into this would b greatly appreciated. Thanks everyone.
Old Jun 25, 2012 | 10:12 PM
Originally Posted by Budsjlm
Multi function switch failure, it is fairly common on 5th gens
this most likely is your answer......
Old Mar 6, 2016 | 08:34 AM
heavyhitter's Avatar
I've checked everything and it's the switch for the blankers.
Old May 13, 2017 | 03:30 PM
mc1978's Avatar
i replaced my multi-function switch and my brake lights still do not work.
Old May 14, 2017 | 03:59 AM
Imp42017's Avatar
I would check that your brake switch is still connected and or working. This is an old Thread that was related to Blinkers. Not sure how the Multi Function switch would help with a Brake light problem
Also If the Brake switch is still good I would check the wiring from the passenger side, THere should be a white wire that is taking the brake light back to the trunk area.
James
randbement
Jun 21, 2017 10:52 PM
dtesgue
May 17, 2012 09:17 PM
bitsy5085
Mar 14, 2009 05:14 PM
thedude
Sep 1, 2006 10:26 PM
