6th Gen ('00-'05): Brake lights?!?
Old Jun 26, 2023 | 05:14 PM
Monteman00's Avatar
Default Brake lights?!?
Brake lights will not work except for the third light that is on the trunk, I have taken it to the shop they said it was the harness but that did not work. The only other thing I can think of is the multifunction switch needs to be replaced, any advice is appreciated.
Old Jun 27, 2023 | 03:20 PM
That's a pretty garbage shop... hopefully they at least gave you some kind of refund.
Before throwing more parts at it, I'd break out the multimeter and wiring diagram and figure out what exactly has failed (which is what the shop should've done in the first place). I agree the turn signal switch is the likely next step (its a very common failure point om the 5th gens), but it only takes a couple minutes with a meter to 100% confirm.
Sanpaoul12
Oct 4, 2014 09:37 PM
DaytonMC82
May 19, 2010 09:21 PM
steves87
Oct 4, 2009 10:01 AM
thedude
Sep 1, 2006 10:26 PM
lazeee
Sep 14, 2005 02:46 AM
