Brake issue..
Old Sep 6, 2009 | 05:25 PM
03Monte's Avatar
Default Brake issue..
ok, today when i got in my car to go buy the stuff to clay bar my baby, i noticed something odd with the brakes...
if i press the pedal down, everything seems normal, but if i let off even a tiny bit and then press down again the brakes go almost to the floor...they still stop, but it goes down way to far for my taste!
any ideas what this may be? do you think that somehow i got air in the line?
Old Sep 6, 2009 | 06:29 PM
RocknSS04's Avatar
It's possible. I'd check the fluid level. Should have a light come on if it gets low. Might have a problem with the master cylinder. also.
Old Sep 6, 2009 | 07:30 PM
03Monte's Avatar
yea, i have no lights on... fluid level looks good...
Thanks for your reply Wayne!
Old Sep 7, 2009 | 01:17 AM
nemesis's Avatar
2009 Monte Of The Year
might have air in brake lines and need to bleed. also i would check all the lines for leaks.
Old Sep 7, 2009 | 01:32 AM
03Monte's Avatar
yea, i plan to check for leaks tomorrow. if i dont find any how could i have got air in the line, i have never removed the brake lines...
Old Sep 7, 2009 | 07:35 PM
jaws2008's Avatar
GOT SPL
i just had to have my master cylinder replaced with a very similar problem, id check that out
whats the milage of the monte, i have and 03 monte ss at 108,000, not that it makes a difference but it could wear out at similar milage
Old Sep 7, 2009 | 07:39 PM
hctr154's Avatar
^^^Not sure how it happens, but you might need to bleed your brakes. Kind of a two person operation too, unless you have some of the new speed type bleeders.
Good luck.
Old Sep 7, 2009 | 07:40 PM
03Monte's Avatar
she only has 65k on her...
I haven't been able to check anything out because it has been raining all day...
Old Sep 10, 2009 | 03:37 PM
03Monte's Avatar
UPDATE:
so after some digging through my brake system i found that the rubber Gasket/boot that is under the Master cylinder reservoir cap was swollen quite bad, not sure what caused it, but i believe it is the source of my air leak.
i replaced the gasket, but im still having the issue (though not as bad), this tells me i still have air in the line, so getting them bled is the next step.
thanks everyone for your help in getting to the bottom of this!
Jerry Barao
Jan 12, 2013 07:54 AM
ladybridgeport
Feb 1, 2012 10:46 AM
heartbeat
Jan 14, 2012 10:47 PM
matrx10503
RWD Tech Guides '70-'88
Dec 29, 2011 10:33 AM
