Opinion Needed: Brake/fluid level/trac control/repaired line
Old Dec 5, 2015 | 06:49 AM
Scott Barber's Avatar
Question Brake/fluid level/trac control/repaired line
I'm hoping to find some help for my '05 MC SS... I blew a front brake line, repaired it, bled the front brakes, refilled the fluid... now my brake, trac control off, and low brake fluid warnings are all on. There was a little play in the FR wheel (like a bearing going bad), I did not bleed the rear brakes, and may have spilled some fluid on something that is causing an issue. However, brakes seem good, car drives fine, and fluid levels are fine. Anyone have any experience with this? I've read several posts, but none I seen seemed to address blown lines and bleeding.
Old Dec 5, 2015 | 07:29 AM
Hiroska's Avatar
You probably have air in the system, you cannot bleed just one line, if you open or blow it, you have to bleed the entire system. I would recommend rebleeding the entire system, starting from rear passenger, driver rear, passenger, and driver side. I recommend using the two person method instead of the one and make sure the master cyl does not go dry. Also check your abs sensor, you may have no plugged it back up if you removed it, you shouldn't have had to though
Old Dec 5, 2015 | 10:50 AM
Thanks for your reply. As soon as I get that second person here to help, I'll give that a try and let you know how it works out.
