Brake Bleeding
my 86 had no rear brakes as the rear brake cylinder let go. I replaced everything and cannot get any fluid to the rear brakes when I bleed them, I changed the combination valve with another used one and still no fluid. Could the master cylinder be bad? I am not sure how long the car has had no rear brakes I bought it that way.
Nope, already tried that. All new line to the back. The only thing that has not been replaced yet is the rubber hose from the rear line to the tee, and the tee itself. Fluid will flow thru from gravity, but no pressure when pumping the brake pedal.
A bad proportioning valve possibly? I had to change the one on my 87 ss because i had too much pressure to the rear brakes, but i imagine they can go both ways.
RickAKATed10
Mar 12, 2010 11:01 AM
