6th Gen ('00-'05): Body Control Module (BCM)
Old Jul 3, 2012 | 05:22 PM
DE02Carlo's Avatar
Default Body Control Module (BCM)
Does anyone have any experience replacing the BCM replacement? I am told if I put a new one in the car will not start unless it is programmed. Is this something only a dealer can do?
I had my car at the dealer today because my fob does not unlock the door it turns the lights on and locks the door but does not unlock. I tested a new key fob already.
The dealer said the car needed a BCM $544 with labor but also said if that does not work it will need a receiver modle $250 so the total could be $794 just to unlock my door with the fob. I paid the diag fee and declined.
Old Jul 3, 2012 | 05:30 PM
That's Sucks because you have low low miles..
It shouldn't have gone out with that low of miles..
Old Jul 3, 2012 | 05:45 PM
DE02Carlo's Avatar
Yes it sucks but you never know when electrical components will fail. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:p></o:p>
I can unlock with the key but kind of annoying. <o:p></o:p>
03SSLE's Avatar
When you say you tested a new FOB you are meaning that you programmed it and the old FOB via the radio?
Old Jul 3, 2012 | 06:12 PM
DE02Carlo's Avatar
Yes I have two other FOB's I programed and it did the same thing. Dealer did it today also.
Old Jul 3, 2012 | 06:20 PM
Originally Posted by DE02Carlo
<O:p</O:p
I can unlock with the key but kind of annoying. <O:p></O:p>
That's how I unlock my 1969 Corvette with a KEY, No FOB..
Old Jul 3, 2012 | 07:01 PM
DE02Carlo's Avatar
We are spoiled ah
When you have a FOB you want it to work....
Old Jul 3, 2012 | 08:48 PM
First as I understand a BCM needs programmed with a GM Tech II. It's in a TIGHT spot. If you take the lower kick panel down on the driverside, it is behind the ebrake and the wiring harnesses are TIGHT against the firewall (3 of them if I recall).
When I tore my dash apart for the evap core, at one part I did infact have to remove the BCM. Now, I cannot remember what all had to be removed to access the BCM easily.
I am hesitant to the issue at hand. Might be worth disconnecting the battery and reseating the BCM connectors under the dash. A BCM and PCM should not fail easily.
And at the replacement cost, I'd almost consider having a shop put in an aftermarket keyless entry, it would probably be cheaper I'm sure.
Old Jul 4, 2012 | 06:20 AM
aussiek2000's Avatar
Can they command the doors to unlock with the techII? If so, it's not the bcm. Do the doors unlock when you take the car out of gear?
Old Jul 4, 2012 | 06:49 AM
03SSLE's Avatar
^^ That was going to be one of my next questions ^^
Also, do both door locks work when operated manually? A defective switch or wiring would have the symptoms you describe.
