6th Gen ('00-'05): Body Control Module (BCM)
Does anyone have any experience replacing the BCM replacement? I am told if I put a new one in the car will not start unless it is programmed. Is this something only a dealer can do?
I had my car at the dealer today because my fob does not unlock the door it turns the lights on and locks the door but does not unlock. I tested a new key fob already.
The dealer said the car needed a BCM $544 with labor but also said if that does not work it will need a receiver modle $250 so the total could be $794 just to unlock my door with the fob. I paid the diag fee and declined.
ffice
ffice" /><o:p></o:p>I can unlock with the key but kind of annoying. <o:p></o:p>
Yes I have two other FOB's I programed and it did the same thing. Dealer did it today also.
First as I understand a BCM needs programmed with a GM Tech II. It's in a TIGHT spot. If you take the lower kick panel down on the driverside, it is behind the ebrake and the wiring harnesses are TIGHT against the firewall (3 of them if I recall).
When I tore my dash apart for the evap core, at one part I did infact have to remove the BCM. Now, I cannot remember what all had to be removed to access the BCM easily.
I am hesitant to the issue at hand. Might be worth disconnecting the battery and reseating the BCM connectors under the dash. A BCM and PCM should not fail easily.
And at the replacement cost, I'd almost consider having a shop put in an aftermarket keyless entry, it would probably be cheaper I'm sure.
Also, do both door locks work when operated manually? A defective switch or wiring would have the symptoms you describe.
