Blower problems
Old Jan 17, 2014 | 08:53 PM
Lilmonte86's Avatar
Default Blower problems
I have a 86 Monte Carlo and my heater only blows on 2 and 3 on the switch on all settings. What could be my problem? Have done replaced switch in the dash and blower motor resistor still does the same thing any suggestions would be appreciated thanks.
Old Jan 17, 2014 | 08:56 PM
Was the switch and the resistor... New? or Used?
If you got them used... You may have gotten another set of faulty ones...??
Or quite possibly, Its the blower motor itself!
Old Jan 17, 2014 | 11:40 PM
Lilmonte86's Avatar
Nope they was both brand new
Old Jan 18, 2014 | 06:42 AM
03SSLE's Avatar
If the blower isn't operating in high position there is an open in the circuit. Pull the connector from the blower motor and probe the power wire (purple) with a voltage meter or continuity tester. With key on and switch in high position you should see approx. 12v at the connector. If not, check for ground continuity on the black wire in the connector. If both wires check out good but the blower doesn't operate then the blower relay is defective.
Old Jan 18, 2014 | 11:00 AM
Mike:
is the blower relay separate from the blower motor? Or is it built into the blower motor?
Old Jan 18, 2014 | 09:50 PM
djhixter's Avatar
check to see if the harness going to the resistor isn't burnt or singed...i had one that did the same thing that was caused by the connector going to the resistor melting and burned the heck out of the harness
bigmike0812
Jan 20, 2013 01:16 PM
sdt1985
Apr 8, 2012 12:11 PM
willysmith
Aug 20, 2006 04:28 AM
Gr4v3_7
May 31, 2006 12:47 AM
willysmith
Dec 12, 2005 08:03 PM
