Is it the blower module
Old Jan 26, 2009 | 02:52 PM
Teacher's Avatar
Default Is it the blower module
Started the car up this morning and drove to work with the blower on hi. Turned the car off and the blower kept running. Started pulling fuses to try and kill it, but no luck. It died before I could find the right fuse. So the problem is that it continues to blow even when the car is off and it blows at high speed no matter where the **** is.
Thanks in advance.
Old Jan 26, 2009 | 03:12 PM
Default RE: Is it the blower module
Hi Todd,
Sorry to hear that you are having problems with your blower.Sorry,
You may want to dis-connect your battery, until you find the
solution.
My Search revealed the below link.
I hope one of our MCF Memberexperts see`s your post & replies
with their thoughts/solutions.
Good Luck from `Space
Sounds like your blower motor control module
Old Jan 26, 2009 | 03:26 PM
Hi Todd,
If no one answers, check out the below links
from other sites with similar problems.
Good Luck
2003 blower motor won't shut off?? - Automotive Forums .com Car Chat
1 post-Last postec 14, 2008[/align]Have a 2003 Suburban that the blower motor won't shut off when the key or dash controls are turned off. Is it the blower motor control ...
www.automotiveforums.com/vbulletin/t933378.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/vbulletin/t933378.html]Similar pages[/URL][/align][/align][*]
blower motor wont shut off - Car Forums and Automotive Chat
18 posts-Last post:Jul 15, 2007[/align]i have a 99 astro van the blower motor will not shut off even when the key is off it ... The one they sent me won't fit in the slot either. ...
www.automotiveforums.com/t713825-blower_motor_wont_shut_off.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/t713825-blower_motor_wont_shut_off.html]Similar pages[/URL][/align][/align][*]
Replaced blower resistor; didn't fix fan speeds - Car Forums and ...
6 posts-Last post:Jun 2, 2005[/align]I changed the blower resistor, but it still doesn’t work. ... on the card part is mostly broken off and the circuits look corroded. ... out of the blower motor resistor to the blower motor on settings 1-4. ... If something gets in the way of the dark blue wire in particular, speeds 1-4 won't work. ...
www.automotiveforums.com/t411937.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/t411937.html]Similar pages[/URL][/align][/align][*]
blower motor resistor? - Automotive Forums .com Car Chat
5 posts-Last post:May 22, 2008[/align]blower motor resistor? Grand Prix. ... I'd also install a cabin air filter for a like year Buick Regal (they won't list one for a Grand Prix because even though the ... Smilies are On. [IMG] code is On. HTML code is Off ...
www.automotiveforums.com/vbulletin/t889914.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/vbulletin/t889914.html]Similar pages[/URL][/align][/align][*]
Intermitant Blower on 1999 '88 - Automotive Forums .com Car Chat
7 posts-Last postec 2, 2008[/align]I replaced the blower motor resistor, and originally thought I was ... centering the armature- it will run until it is shut -off again- and ...
www.automotiveforums.com/vbulletin/t931739.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/vbulletin/t931739.html]Similar pages[/URL][/align][/align][*]
Suburban - Car Forums and Automotive Chat
Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/ Tahoe > Suburban ... 94 surburban · 2003 blower motor won't shut off? ...
www.automotiveforums.com/f1451-suburban.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/f1451-suburban.html]Similar pages[/URL][/align][/align][*]
Chevy Colorado Issues - Car Forums and Automotive Chat
33 posts-Last post:Jan 9, 2008[/align]I got the truck back on Jan 7 2005 and the blower motor wasn't fixed ... that I filed a claim against them) Hopefully this won't take to much .... Downshift, turn key off, emergency brake, swerve to curb, etc. ... The armrests are "loose" and squeek when pulling the door shut or operating the PWs. ...
www.automotiveforums.com/t350446.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/t350446.html]Similar pages[/URL][/align][/align][*]
Blazer - Page 21 - Car Forums and Automotive Chat
Automotive Forums .com Car Chat > Chevrolet > Blazer ... 98 Blazer..How to turn off Day Time Running Lights? ... Fuel Tank Pressure Sensor · 96 S10 Blazer heat Blower motor · 4X4 fuse · 4X4 fuse · 85 Chevy Blazer · keyless entry remote, ... Ignition switch won't turn off and release key · regarding temp gauge ...
www.automotiveforums.com/f119-21.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/f119-21.html]Similar pages[/URL][/align][/align][*]
97 cavalier z24- heater fan? - Automotive Forums .com Car Chat
5 posts-Last post:Jan 28, 2008[/align]Most likely is the blower motor. Or it could be the resistor gone as ... It won' t turn off if I try pushing the button and it doesn't do it ...
www.automotiveforums.com/vbulletin/t885460.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/vbulletin/t885460.html]Similar pages[/URL][/align][/align][*]
Impala / Impala SS - Car Forums and Automotive Chat
Automotive Forums .com Car Chat > Chevrolet > Impala / Impala SS ... Early Converter Engagement · 2000 Impala blower motor & DIC doesn't work ... switching overhead console to km. from mph · fans won't shut off and bloe hot air with a/c ...
www.automotiveforums.com/f112-impala___impala_ss.html - http://www.automotiveforums.com/vbulletin/index.php%3BL:http://www.automotiveforums.com/img/logo_s.gif%3BLH:50%3BLW:202%3BLBGC:FFFFFF%3BLC:%23 0000ff%3BVLC:%23663399%3BGFNT:%230000ff%3BGIMP:%23 0000ff%3BDIV:%23336699%3B&domains=automotivefo rums.com&sitesearch=automotiveforums.com&s ig=xj2sALBGxv03Twmd&flav=0000&ad=w9&ie =UTF-8&oe=ISO-8859-1&q=related:www.automotiveforums.com/f112-impala___impala_ss.html]Similar pages[/URL][/align][/align]
Old Jan 26, 2009 | 03:33 PM
Teacher's Avatar
Hey thanks space. That is what I was seeing as well when I googled the problem. I am pretty sure that is what is and was wondering if anyone else had the same problem and what they did to fix it.
Old Apr 5, 2014 | 04:35 PM
Skialdi's Avatar
Unhappy Blower Motor Stuck Running.
I am having this exact problem. My blower motor will not turn off even when the car is off. I had to unplug the battery. After pulling all the fuses related to the blower, and nothing happening, I was thinking it was the switch, but when I disconnected it nothing changed. Do I need to put a new one on for it to work?
Old Apr 5, 2014 | 06:43 PM
iMuf's Avatar
My Monte did it when I had it and it ended up being the Blower module. It's an easy fix, just stinks to buy since it is fairly expensive
Old Apr 5, 2014 | 07:45 PM
5 year old thread...
couch
Mar 25, 2008 04:21 PM
kweef
Mar 9, 2008 07:39 PM
jogasz28
Jan 29, 2007 05:06 PM
keghead40
Jan 7, 2007 03:08 AM
orthokneepa
Dec 2, 2006 12:19 PM
