6th Gen ('00-'05): Belt Problems
Old May 21, 2016 | 11:02 AM
tj272's Avatar
Question Belt Problems
My serpentine belt will not stay in place. It appears to be slipping off the back (engine side) of the crankshaft pulley. I think it looks like that pulley is out of alignment with everything else. What would cause the crankshaft pulley to misalign? Hopefully these pictures will help show what I'm trying to describe. Any help will be appreciated.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old May 21, 2016 | 03:24 PM
Is your crankshaft pulley bolt tight ?
Old May 21, 2016 | 03:34 PM
plumbob's Avatar
Hi tj.
That pulley is the harmonic balancer and it is coming apart. A rubber bushing separates the two pieces. By chance was the crank sensor replaced recently? If so, the wrong pulley remover tool/technique may have been used to remove the balancer to access the sensor. The harmonic balancer needs to be replaced.
Watch this video that tells the whole story:
Old May 21, 2016 | 05:35 PM
tj272's Avatar
I haven't checked that yet
Old May 21, 2016 | 05:40 PM
tj272's Avatar
Originally Posted by plumbob
Hi tj.
Premature belt wear and noise, Damper replacement GM 3400 - YouTube
Hi plumbob,
Thanks for the reply. You confirmed what I was figuring the only solution could be - to replace harmonic balancer. I can only assume it just normal wear failure, since no work has been done to crank in the past. The only repair in conjunction with belt was last Aug the ac compressor seized, and I had to replace it along with the shredded belt. Possible that ultimately caused this failure, but I can't really call it premature, this is, after all, my daily driver and has 181k on it.
Old May 22, 2016 | 08:28 AM
plumbob's Avatar
Thanks for the follow up tj.
Not a difficult job, just be sure to get the woodruff key in the groove on the crank properly when you install the new one.
Old May 22, 2016 | 10:59 AM
turbo monte's Avatar
I think I have a good used harmonic balancer if your interested. Idk what shipping would be though, kinda heavy.
Old May 22, 2016 | 11:16 PM
tj272's Avatar
Hey turbo, thanks for offering, what would you want for it?
Old May 23, 2016 | 05:41 PM
Idk honestly, if your interested I will look for it. Make me an offer. Shipping will be expensive though I bet
Old May 23, 2016 | 06:59 PM
tj272's Avatar
Let me get it removed first. Auto Zone has new aftermarket one for less than $60 in stock. That may be my better option. Thanks.
