7th Gen ('06-'07): BCM issues?
Old Oct 19, 2024 | 12:31 AM
Redheada_rule's Avatar
Default BCM issues?
I have a 2006 Monte Carlo SS. I think there is a parasitic drain because the battery kept dying then no longer held a charged. So replaced it and now the radio says locked and the windows do not work and no crank no start. Had another key made by a legit locksmith and replaced the ignition switch. still no crank no start, radio still locked and windows still don't work. Before I replace the BCM is there a reset procedure? And does it matter which part number? because if I look up a bcm by vehicle it's not the same as the part number on the one currently in the car.
Redheada_rule
Jul 12, 2025 08:55 AM
NYGiantsfan
Jan 5, 2016 06:14 AM
Brandon Thompson
Apr 5, 2013 05:30 AM
DE02Carlo
Jun 2, 2012 09:28 PM
Curtis24682007
Jun 26, 2011 07:33 PM
