Battery issues?
Old Mar 18, 2015 | 01:11 PM
charvel5150's Avatar
Default Battery issues?
Guys i have a 06 ss and when i go to start it it will have power to dash lights interior and such but when i turn the key everything goes dead. Battery has a little over 12 volts i installed new battery cable terminals and still nothing. if i pull the fuse for the battery or disconnect the battery and reconnect it will have power again but goes completely dead soon as i turn the key to start it. Any ideas guys?
Old Mar 18, 2015 | 01:39 PM
I think the first place you need to start is to make sure that your battery terminals and both ends of each of your battery cables and their contact points are clean and free of corrosion.
Old Mar 18, 2015 | 01:47 PM
Yeah both cable terminals are brand new. This thing sat on a battery tender all winter and last time i fired it up in late December it was still fine.
Old Mar 18, 2015 | 02:03 PM
I just seems like something is not making proper contact with it instantly going dead when you turn the key. I always just start with the free fixes first..checking every connection at each terminal, the starter, and the grounds.
Old Mar 18, 2015 | 02:20 PM
yeah that's what it seems like to me too. Its not a surprise this thing is having another electrical issue I've had the car 2 years and its been broke down more than running due to one thing after another breaking on it.
Old Mar 18, 2015 | 02:23 PM
Well hopefully it is one of the free fixes and you have it running again in no time!!
Old Mar 18, 2015 | 02:29 PM
Hope so because its a blast to drive. Thanks for the help i appreciate it
Old Mar 18, 2015 | 02:34 PM
No problem!! Let us know when you find out what was causing this problem.
cnogood
Sep 20, 2014 04:16 PM
70monte1
Jun 14, 2012 05:12 AM
thumpingetocar06
Oct 16, 2009 03:47 PM
DCfla
Aug 20, 2009 01:26 AM
roflcopter
Mar 23, 2009 11:55 PM
