Battery Alternator Compatibility
Old Dec 15, 2009 | 09:12 PM
Bait's Avatar
Question Battery Alternator Compatibility
Hi, Thanks for looking, I have a 01 LS. I am wondering on, if you up the CCA from 650 to 800, or close to, on the battery. At the time of replacement of the alternator would you not also need to up the amperage to be compatible and fully charge the battery. In theory, the battery would not be getting enough current (if the alternator stayed Stock) to Fully power it and then putting a drain on the Entire electrical system.
How much tolerance Do BOTH Battery and Alternator have without having to make an immediate change?
How much amperage is needed to power a battery?
Thanks, as I am sure this was posted 20 pages ago.
Old Dec 15, 2009 | 09:23 PM
kweef's Avatar
The larger battery would take slightly longer to get back to full charge after a start, but besides that nothing should change. you shouldnt need to up your amperage with a high output alternator unless u r making incredibly short trips (under a few minutes) your alternator should do just fine...
marshagup
Mar 25, 2015 01:11 PM
David Brandhorst
Dec 2, 2013 06:20 PM
ladybridgeport
Mar 19, 2012 09:14 AM
NovaSS369
Aug 23, 2011 12:45 AM
silver1
Mar 1, 2009 11:57 AM
