bad leak
Old Feb 4, 2008 | 09:14 AM
chevy804's Avatar
Default bad leak
I have a 1999 MC with a 3.1 liter in it with 108000 miles on it there is a coolant leak on the passanger side i can see it drip-run out down below the alt any help plz need this to drive diesel just to exp.
Old Feb 4, 2008 | 09:45 AM
Default RE: bad leak
Hi Keith,
Sounds like a bad heater core.
or
Coolant leak: Coolant loss via plastic intake manifold is corrected by installing upgraded manifold and gaskets plus new PCV kit. (1995-01) [/align]It's difficult to give a specific answer without viewing[/align]the problem area. I hope one of our expert member's[/align]will read your post & give you a solution to your problem.[/align]Good Luck `Keith.[/align]If all else fails[/align]
[/align][/align][/align][/align]
Old Feb 4, 2008 | 11:07 AM
mickey's Avatar
2 things to check.
1. check the bottom of the water pump and make sure it is dry.
2. as was said make sure the intake its self is not leaking.
also you can go to Autozone and get a leak kit relitivly cheap it might be a worth while investment for you at least then you could see where it is .
Good luck hope it is simple
Old Feb 6, 2008 | 11:20 AM
chevy804's Avatar
It's not the water pump or the heater core any info about the intake would be great i need this car to go down the road thanks much
Old Feb 6, 2008 | 01:26 PM
bonang's Avatar
3.1's arnted they known for the intake gasket or the head gasket?
TMoney
Apr 9, 2014 09:32 AM
MonteSquarlo
Dec 16, 2012 06:18 PM
monte67
May 25, 2012 08:16 PM
rj
May 19, 2010 07:34 PM
Overdose666
Apr 8, 2010 08:36 PM
