7th Gen ('06-'07): Bad knock after oil change
Old Aug 31, 2015 | 03:11 PM
KissMy06SS's Avatar
Default Bad knock after oil change
Hello all, soi bought a 2006 Monte Carlo 06 SS about a year ago with 60k miles. I regularly maintained her and have always loved the cars. Unfortunately I had a few issues and the last oil change I let slip my mind and hadn't done it in 7k miles .Typically I am very meticulous about everything but it slipped. I just rolled 80k miles on the car and have done the changes previously every 3k miles.... So I did this one after 7k. when I did the change I drained maybe 2 quarts of oil from the pan. Didn't look bad at all but obviously 2 quarts is not good, the car never had any issues besides this happening. Never smelled like burnt oil and never smoked, now that I did the oil change I have a real bad tick. Sounds to be a lifter tick. Any suggestions on how to make it go away or do you think its time for a new motor/rebuild. Some have said they left it and It just kinda went away after awhile but id rather not risk doing anymore serious damage to the motor.
Old Aug 31, 2015 | 10:38 PM
If you only took out 2 quarts of oil then unfortunately your engine is probably done. LS4's take 6 quarts but with displacement on demand they're notorious for oil consumption. Make sure you've got the correct amount of oil. Aside from putting some additives in i dont really have any ideas.
