Bad Fuel Pump
Old Mar 17, 2011 | 01:05 PM
Sparky-88's Avatar
Default Bad Fuel Pump
My old car, Alice, a 1990 Jaguar XJS, experienced an issue recently. And even though it's not a Monte, I'd thought I'd share since the problem is one that could happen to most cars and someone might learn from.
A couple months ago, I noticed a slight stumble in the engine, usually at low speed / RPM. It would only last a fraction of a second. It was so slight at first that I didn't know if I was imagining it. Over the next few weeks, it started happening more frequently and lasting longer, up to 5 - 10 seconds. And eventually it happened at a variety of speeds / RPM.
Turns out my fuel pump was slowly dying. It was working, but was not putting out the proper fuel pressure. And apparently it would 'hiccup' now and then making the engine noticeably stumble. I ended up bringing her to my mechanic for diagnosis / repair. I knew that the fuel filter and pump were on the short-list of possible culprits, but also realized it could be a few other electrical / ignition things as well. I didn't want to just throw new parts at the problem without some diagnosis.
I pick her up Fri morning. With any luck, the fuel pump was the only thing causing the engine to stumble. If it turns out otherwise, I'll post an update.
ReaperSS
Aug 29, 2014 11:35 AM
TMoney
Apr 9, 2014 09:32 AM
The_Maniac
FWD Tech Guides '95-'07
Jan 26, 2014 05:54 PM
vincenti
Jul 31, 2013 07:34 PM
motivation2k3
Oct 18, 2007 06:16 PM
