Backup Cam with Dynamic Gridlines
Old Mar 21, 2023 | 04:30 AM
jthorpe's Avatar
Default Backup Cam with Dynamic Gridlines
Is there a way to install a backup cam to an 07 Monte LT that has the dynamic gridlines? I'm looking to see if it's possible to add one where when you turn the wheel while backing it'll show lines on the trajectory of the way the car will move.
Another question is can you have the radio head unit swapped out with one from a Camaro to gain some of the features a Camaro radio head unit has?? (I know some of the wiring may need to be modded, but didn't know if it'd fit in the double din or if it can be programmed to the car).
Info: Projected path are the static lines that don't move. Dynamic gridlines are the ones that move as you turn the wheel.
Roywow
14
May 31, 2024 08:38 PM
blackss03
Nov 23, 2014 07:03 PM
csmith045
Mar 15, 2009 08:05 PM
BankheadSS
Sep 27, 2007 10:20 AM
c1benny
Oct 16, 2005 02:29 PM
