anyone try these zzp bulbs?
http://www.zzperformance.com/grand_p...d=94&catid=101
I've been tempted to get them but id need the combo since my Monte is an 04 but I thought I would ask here first since I browse around quite a bit...so anyone have any experience or recommend a nice set of bulbs with that nice blueish tint to them for a decent price? edit: sorry if I posted this in the wrong place on the forum, I wasn't sure where to put it |
I once used xenon bulbs. The heat melted and fused my harnesses and created a fire danger.
i had xenons once, i would just get hids, spend the extra bit to get the better bulbs
back away from those man. they could F ur headlight housing up. if you want bright N SAFE go with real HID
I would just get silverstars or silverstar ultras. They appear to be expensive, but if you shop around you can get a set for $20
I moved your topic to the general tech spot, since detailing is more for cleaning the car :) |
Depends on what you're wanting them for. You want them for the look of hte headlight, or for visibility. Ebay has some colored ones taht dont get too hot. Its not a deep color, just a little tint. I used somthing similar befor in my monte and didnt have a problem, BUT and a HUGE BUT, they were not 100W, they were 60W
(Post 248534)
I just got a pair of silverstar ultras on amazon for $25 for the pair!!!!
sweet, thanks for the advice and i'll check into those silverstar ultra's
I don't mind spending a bit of money for a nice look to them, I would like to get a set for my low beams and high beams but i'll definently shop around for those silverstar bulbs and check which ones will fit my 04, thanks again edit: i found this post by searching around
(Post 183536)
2003 CHEVROLET Monte Carlo Low beam headlamp 9006 9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen 9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen 9006EB EcoBright - Your Environmental Choice 9006XV XtraVision Halogen - The Brighter Light 9006CB Cool Blue Halogen - The Whiter Light High beam headlamp 9005 9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen 9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen 9005EB EcoBright - Your Environmental Choice 9005XV XtraVision Halogen - The Brighter Light 9005CB Cool Blue Halogen - The Whiter Light |
Yes they will work 2000-2005.
