another flasher problem
Old Jan 28, 2009 | 11:39 AM
bignate's Avatar
Default another flasher problem
so i tried looking on the other threads and i couldnt find anybody else with the same situation.
my problem is that my front left turn signal doesnt work and the rear blinks twice as fast the weird thing is that if i go on an hour long drive it will sometimes fix itself but only temporarily and then go back to the same problem.
i have already replaced the blinker bulb, and the hazard flasher button relay and the same thing is going on
any ideas? is there anysort of secondary flasher that might not be working?
Old Jan 28, 2009 | 11:40 AM
bignate's Avatar
Default RE: another flasher problem
oh i forgot to say its an 01 monte carlo ls
Old Jan 28, 2009 | 11:57 AM
RickAKATed10's Avatar
Photobucket
What about a fuse? I'm not sure, but it is an idea.
Old Jan 28, 2009 | 11:28 PM
kweef's Avatar
or u could have an open in the wire sumwhere between the flasher and the bulb...check for resistance from the flasher to the bulb. if it there is resistance (.02 doesnt count) then u know there is a break
Old Mar 5, 2009 | 02:50 AM
robh68chevy's Avatar
i also have an 01 ls and i had the same problem a few months back. it ended up being the light socket. i just pulled my headlight assembly out and took the flasher bulb out and used a small screwdriver to bend the contacts slightly out. dont bend them too much though because they might break off im not sure. its worth a try only taked about 5 minutes. let me know what you find out.
ladybridgeport
Apr 27, 2013 05:04 PM
ladybridgeport
Jan 29, 2011 10:59 PM
old man metal
Dec 13, 2007 06:36 PM
kent00SS
Jul 16, 2007 03:56 PM
Lee55
Jun 9, 2006 09:20 AM
